Hello,
I am buying a new system to install in my sisters place and I was hoping that someone could give me a few pointers. I am an audio installer and dont really do much with alarm systems but I figured I would give it a shot (with help from some friends who have more experience in alarm install). In any case here goes!
I have approximately 100 zones that are comprised of:
Basement Panel (includes basement, 1st floor and garage)
18 doors
7 motions
19 Glass Breaks
1 siren
4 smoke Detectors
2 CO Detectors
12 Window Contacts groups
1 Heat Sensor
3 Arming stations
4 Keypads
Second Floor Panel
2 Door Contacts
2 Motions
7 Glass Breaks
1 Siren
5 Smoke Detectos
5 CO detectors
7 Window Contact Groups
1 Heat sensor
1 Arming Station
1 keypad
I am ordering the following:
ELK-M1KPAS M1 Arming Station (4
ELK-M1GK Control + Transformer + Keypad + Battery + Speaker + RJ31X Jack & Cord + 14" box (1)
ELK-SWB28 (28" enclosure) (1)
ELK-SWD1 (Grommet Donuts) (4)
ELK-M1PR Keypad Plug-in Proximity Reader (1)
ELK-M1PRF Proximity Fobs for ELK-M1PR Reader (Pack of 10) (1)
ELK-M1KP3 LCD Keypad (4)
ELK-M1XIN M1 16 Zone Input Expander (6)
ELK-RP (remote programming software) (1)
ELK-USB232 (1)
RCR50 50 ft PrecisionLine Dual Technology Motion Sensor (GE) (9)
SR-5812RND (GE Glass Break detector) (26)
EK-73 Speaker Siren (1)
GE Security 240-COE Carbon Monoxide Detector, (6)
4WTAR-B 4-Wire, Photoelectric I3 Smoke Detector (system sensor) (14)
BK-RRSMODPolarity Reversal Module (1)
5622 194-Degree F Fixed Temp/Rate-Of-Rise, Dual-Circuit Heat Detector (system sensor) (2)
ELK-M1XEP (ELK ethernet interface) (1)
Cell Guard Tellguard TG4 (1)
Sorry about this long list but I was hoping someone could tell me if this stuff looks ok (compatable). The smokes are the 4 wire type C units which I believe is what is required. My question regarding this is if I have a remote panel upstairs, and if I want to daisy chain the smokes upstairs and do the downstairs ones separately, do I need 2 polarity reversal modules? My understanding is that the panel upstairs connects via a single cat 5 to the panel downstairs. What do I need apart from a power supply to the upstairs panel? Is there some sort of module that I need from elk to make this work correctly? there are approximately 25 zones upstairs including all of the smokes in series as 1 zone.
Another question is regarding the window contacts. Every single window was home run to the basement panel or second floor panel. At that location, I was basically going to connect windows for each separate room together so as to avoid having a million zones so for example 3 wires for bedroon 3 will be connected together and 1 whip will be pulled from this. should I use the gel phone wire connectors for this or what would you suggest? some rooms have 8-10 windows...
In terms of the battery backup and the number of expansion cards for zones, is the battery that comes with the second floor will have the 14" housing and 2 x 16 zone expansion cards. Also there will be a honeywell power supply kit to power this panel HP312CX (includes a backup battery etc). THe basement panel will have the 16 exisiting zones on the panel plus 5 x 16 zone expansion cards for approximately 96 zones available. Do I need more battery backup here for this panel than what is provided?
Another question is regarding resistors... do I need them, can I do without?
I know there are some people who work for elk on this forum but for whatever reason I am not allowed to send them an email.
Any help or advise would be greatly appreciated. Also, If anyone knows a good installer around chicago, that is relatively reasonably priced, could you let me know? I will name a zone in your honor if this gets up and running!!! thanks much.
18 doors
7 motions
19 Glass Breaks
1 siren
4 smoke Detectors
2 CO Detectors
1 Heat Sensor
3 Arming stations
4 Keypads
Second Floor Panel
2 Door Contacts
2 Motions
7 Glass Breaks
1 Siren
5 Smoke Detectos
5 CO detectors
1 Heat sensor
1 Arming Station
1 keypad
ELK-USB232 (1)
