I am setting up a detached structure with a remote power supply, input expanders, output expanders, strobes, UPB lights, and multiple sirens. I am having difficulty writing a rule that will turn off multiple outputs/lights once the BURGLAR CUTOFF TIMER expires. Rule #1 and #2 work fine. Rule #3 does not turn off any of the outputs/lights once the alarm cuts off. A gentleman in your tech. dept. suggested I set each output for specific time duration. I realize that would work but I would need to make sure all the outputs/lights are timed correctly. It is much more compact and efficient if I can get rule #3 to work properly and have the cutoff timer handle turning everything off. The system is running firmware 5.2.4
Here are the three rules in question:
Rule #1: THIS RULE WORKS PERFECTLY.
WHENEVER THE BURGLAR ALARM IN Detached Garage (Area 1) TURNS ON
THEN TURN Remote Siren (Out 3) ON
THEN (multiple other outputs and lights are turned ON.
Rule #2: THIS RULE WORKS PERFECTLY.
WHENEVER Detached Garage (Area 1) STATE BECOMES DISARMED
THEN TURN Remote Siren (Out 3) OFF
THEN (multiple other outputs and lights are turned OFF.
Rule #3: THIS RULE NEVER TURNS OFF ANY OF THE OUTPUTS/LIGHTS.
WHENEVER THE BURGLAR ALARM IN Detached Garage (Area 1) CUTS OFF
Your help is appreciated!
