Udate..I can now verify the the code works...
I inserted a (temporary) miscellanous voice announcement in my code and the relay expansion module has LED's on each relay which come on when activated.
On Odd days it activates and on Even days it wont!
The only thing I may have to eventually do is increase the (10 Second) trigger timer in order to insure that I get a delay between each valve.
I noticed that some appear to have slightly less delay time between them due to different run times .
I don't think this is a major issue and ithe initial 10 seconds can probably be increased up to five minutes or more since I have at least 6 hours to get the watering done between 12:01 AM and 6:?? AM.
I think I will probably also move the lines that turn Outputs 201 through 205 off from the first to the last WHEN statement just to insure that I don't have a valve on for 24 hours. As it is now this is not done until the cycle starts. :unsure:
See my initial post #8 for final (Complete Code) to do this.
Thanks for everyones's help...
