bucko
I'm trying to get my head around addressing the outputs of the M1RB and the M1XOVR as it relates to to M1 control. I cannot find info, searched long time.
First off, I am using J-16 on the M1 to connect to my M1TWA(J4). But I still need programmable outputs via the M1RB and the M1XVOR available through the RP software programming. I jumpered M1RB (J1) to the M1XVOR (J3). Then ran data connection between my DBHUB and the data connector of the M1XVOR. I set the address to 2.
Should I now be able to program the 8 relays of the M1XVOR plus have the 8 relays of the M1RB. So I would have a total of 16 programmable relays present?
I will use the M1RB relays to connect to the ELK 124 to fire custom sounds. The 124 audio out connects to pin J5 and J6 on the M1TWA (J1).
Is this a correct way to do this? I am just at the connections phase before I power anything up.
Thanks...
Thanks...
