I'm using the serial port, i will try Hyperterminal when I get home.How is your PC connected to your M1? Is it a serial or network connection?
Network (M1-XEP)
If the M1's address is 192.168.0.251, you can connect to it like so: telnet 192.168.0.251 2101
You can also use Hyperterminal. Set "Connect using" to TCP/IP, "Host Address" to 192.168.0.251, and "Port" to 2101.
Serial
Use Hyperterminal and set "Connect using" to the appropriate COM port. Ensure the serial port settings match those used by the M1.
If you're using an M1-XEP, you should see the "XK" command broadcasted every 30 seconds. Arm/disarm the M1 and the corresponding commands will be displayed in the telnet/hyperterminal session.
Let me know your results and we'll take it from there.
