BraveSirRobbin
Moderator
I know this can be cleared locally via the keypad but I don't have that option anymore (long story):
I have an Elk M1 Gold with all the latest updates and used to have that system monitored via IP/XEP with a monitoring service.
I stopped the monitoring service and wanted to clear the settings (again remotely) from the M1. I did the following:
I'm getting a "Failure to Communicate" message flashing on the system. In the past, this happened when the system failed to test to the monitoring station overnight (had this setup to test every night with the monitoring service station).
It's like the system still thinks there is a monitoring service available.
How can I clear this message remotely? I don't have any access to the system locally. I did all of the above yesterday, hoping the error would have cleared by morning.
- Deleted the monitoring setup in the XEP tab, sent that configuration to the Elk M1 and restarted the XEP
- Deleted the telephones (even did a 'receive all telephones' to ensure none existed in the Elk)
- Made sure no telephones existed in the G01 Globals setting.
