Exactly which was what was said in simpler terms in post #4.
However, you do NOT want to get into the practice of doubling up pairs of undersized conductors to make up for an improper size AWG for the voltage drop or ampacity. This is a poor practice to get into, let alone suggest. Basically, it's putting the load in parallel, which is a no-no by code and as a secondary issue, it can also contribute to it's own host of problems.
Keep in mind, the 4000' is end to end, but once you do a feed and return topology, it is cut in half, so 2K' end to end is easily met in most common installations, so either a topology or wiring method change is needed (be it via a retrofit hub or daisy) but the retrofit hub also has it's own items to consider before saying it's a fix-all solution.
