ccmichaelson
Based on lots of research (mostly here) I ended up pulling 18/4 firewire in a daisy chain configuration from my Elk M1 Gold panel to the smoke/co locations (panel -> smoke1 -> smoke2, -> smoke/carbon3, etc.).
I'm planning to purchase (qty 7) Security Sensor 4WTA-B (4-wire smoke detector w/ thermo & sounder) and (qty 2) System Sensor COSMO4W smoke/carbon detectors + COSMOD4W Interface
If I understand it correctly, the wiring should occur as follows:
- Elk Panel -> COSMOD4W Interface -> Smoke Detector #1 -> Smoke Detector #2 -> Smoke/Carbon Detector #1 -> etc... EOL Resistor at the end of daisy chain
- Where do I put the reversing relay - or is that what the COSMOD4W interface is for?
- Can I daisy chain smokes and smoke/carbon combos?
- Would you recommend a different setup?
