Elk M1 Wireless group changed to hardwired
smolino
I have a zone group on my M1G that is shown as a hardwired group but they are wireless devices. I'm not sure when this changed, I configured each of the zones through RP with their wireless parameters several years ago. The zones all operate correctly.
Is there any way to change the designation without deleting the group and adding it back in? Since RP doesn't recognize the zones as wireless there doesn't appear to be any way to display the wireless setup parameters. I would need to go to each wireless transmitter and open it to determine the transmitter ID to rebuild the zones.
Any suggestions would be appreciated.
Did you back up your account settings years ago when you set the system up?
Mike.
One thing that I would try would be to set up a new account and read all of the settings from the M1 into the new account using RP.
Mike.
Unfortunately I do not have a backup of the database from prior the the problem. I did attempt to create a new account and import the panel, no luck. I ended up just deleting the corrupt zone group and rebuilding it. Lesson learned.
