Elk M1 XEP update - can't connect to XEP anymore
signal15
I was on something like 1.30, and I updated to the latest version (updating the bootloader first, and then firmware).  I waited 30 mins, and tried to reconnect.  No go.  I power cycled it, and still cannot connect.
Any ideas?  Did it whack my whole config?  What's the default IP on it?
Edit: Nevermind, I switched the port to the secure port and then it works. Not sure why it's not working on the unsecure port as my Vera can connect to that one just fine.
Updated to boot 2.0.4 and firmware 2.0.42.  It's working now.  I had switched it to the unsecure port to connect because the time was WAY off and I couldn't connect (probably because SSL doesn't work right when the time is way off).  Before I updated it, I fixed the time/date.  It then wouldn't connect on the unsecure port, but the secure one works now.
