Elk M1 zone vs. local keypad zone
tisserda
What is the advantage or running a zone from the local keypad vs. having all tied back to the central controller? Other than ease of wiring, nothing stood out to me in reading the manuals as an obvious advantage/disadvantage.
That's it - just having a zone where there's a keypad. Part of the idea is that each keypad supports an RFID reader and with the local input and output, you could often control a nearby door for an electronic latch - so you can get RFID, Door Contact, Keypad, and Electronic Latch trigger all from that single Cat5.
I'd call the input more of a convenience feature for a takeover of a system with a similar arrangement or for a retrofit application. In a new install, I would recommend running the cable to begin with.
The output isn't really of too much use unless you use it as a voltage trigger or sink, as it's too "light" to support anything else without a relay. I commonly use them to drive the LED on external weigand readers to drive the red/green LED on a standard reader, then make appropriate rules to act like a normal ACS for lighting events. In the case of a reader, you're going to be interfacing either with the keypad (pigtail) or a KAM, but that's a different animal, so keeping the LED trigger at the keypad with the weigand data makes more sense.
Again, based on the additional hardware, I would recommend running the wire for a true output back to the panel.
