Guys, I have an Elk M1G hooked up...I have already installed a magnetic sensor on the garage door so I can sense when the door is open or closed. I have also programmed one of the keypad's "F" keys to show if the door is currently opened or closed.
Now here is the question: I would like to program the system so when I push the corresponding "F" key the system can close or open the door.
I have already run a wire from the elk to where the "doorbell" type pusher goes. However, the "doorbell" push button is illuminated showing about 3.8V DC (as tested with a multi meter). Can I simply hook the single pair wire to an elk output? If so, will the voltage on the wire "hurt" or damage the system in any way. When this is finally connected I would assume that I could write a rule that states "When F key is pushed turn output X on for 1 second"?
Thanks for your help,
Dave
Dave
