Retrofit install, 28" can (plus another small one) on a wall in a closet.  There is NO outlet in the can, the transformers are mounted on outlets nearby.
I understand one does not ground the panel itself.
Should I ground the can? Is there any code requirement to do so (generally, in the US) with no line voltage inside? Is there any technical reason? (With the panel not grounded and not connected to the can, and no RF inside the can, it is hard to see that it matters)
Perhaps more importantly if so - how? Partly esthetics, I hate to run a wire over to the outlet and do something like run it under the face plate. I am not sure that's even legit. Was thinking of a cord, only connect the ground wire, and plug it in. Sounds safe and also not legal?
There's a small ground wire lug on the transformers, I could run plug it in, but 18g ground wire feels a bit wrong.
There's no other good ground source nearby other than the protective ground inside the outlets.
Is there a normal practice in such cases? Or do people just not bother grounding the can if there is no line voltage inside?
		 i), however most systems get further restrictions removed in 250.162:2 and 3.
