My 20+ year old Napco Magnum alarm system was fried by lightening and I now have an excuse to install an Elk. I haven't purchased the ELK yet (although I have disconnected the old system and carefully labeled the wires). I have a couple of preliminary questions which I hope someone can assist me with.
1. My old system has 1000 ohm EOL resistors connected at the panel at the negative terminal on the old panel of each zone. Do I use these, snip them off, use Elk resistors or use no resistors? I have read the posts about EOL resistors but really don't understand how they apply in my situation.
2. My old system has glass breaks terminated to a 3 zone "multi-output analyser' Maximal MA350' which in turn was connected to zone 7 of my old alarm (and aux power). Do I connect the MA350 to zone 7 of the ELK or is some other method or wiring required or some other interface required?
3. I want the ELK to control some critical insteon lights and also connect to my PC to check alarm status and interface with PowerHome which I use extensively. I am considering the Elk Smarthome package which includes the M1 Lightening interface or instead the Ethernet device. I'm leaning toward the Ethernet device because my router is next to M1 space and I don't particularly want to deal with another PLC. It is unclear to me whether I would get the same functionality from either or whether one is better than the other for my purposes. Anyone have any insight on this issue?
Thanks to all.
Thanks to all.
