ELK-M1KP2
nov0798
Does anyone know how to make the keypad lights stay on, with the M1KP2 keypad? I just replaced an M1KP with this unit. The M1KP's keys always stayed lit unless you told them to turn off after the 60 seconds. This keypads lights shut off regardless. Any ideas?
I'm not sure if you can set it from the keypad, but it's settable in RP. I have some KP2s that are off all the time, others after a period of time.
Kevin
You can go to end user menu 8, keypad settings, and adjust the dim level of the back light. After hitting a key, the back light stays full bright for about 30 seconds and then dims to the setting.
Does anyone know why the ELK button is so much brighter than the other buttons? Its brightness doesnt seem to change regardless of settings.
