Hi there,
I am installing a wood burning insert into my fireplace shortly and that got me thinking about the posability of having my Elk M1 alerting me to an undfire or overfire condition in my stove. Basically, you want to keep a wood stove burning between 400 to 600 degrees for proper usage.
If the stove drops below the 300 degree range, then either your running low on wood or your not burning right and potentially creating dangerous creosote in your chimney. At 700 + you are getting dangerously close to overfiring the stove and have glowing red metal in your house. Neither is good. Since the stove has the ability to burn up to 12 hours on a load, it is unlikely that we will be watching it carefully for the entire time, especially overnight.
Does anyone know of a remote temp. sensor with the kind of range needed for this application? Wireless would be better as the fireplace is all brick and no easy way to run wire to it. it would need to be a physical contact sensor that could be place on the stove surface to monitor the temp.
I also have a Isy99i and Insteon infrastructure in place if there is anything in that world that might work.
I have several Insteon thermostats that can monitor room temp but that does not help too much.
Any ideas?
Thanks!
Any ideas?
Thanks!
