ELKRM uses Visual Basic 6 and ELKRMS uses Microsoft .Net. Make sure you have .Net Framework installed on your computer.
How do I connect to different Elk panels using the same program, I have a ser # for each panel.
I would need a different ip address setup for each panel, is their a easy way to select which panel you want to connect
to?
Mark
Bump
Mark
to?
Mark
Bump
Mark
Mark to my knowledge this is not possible.
Why would you want/need to connect to different panels from the same software?
yeah - it's available... see Spanky's link above. Even if your distributor can't sell RMS, you can buy the RM license - it's the same key, so it doesn't matter. You're buying the key more than the software - the software is right on the web-site available for download - then you can plug your key in to unlock it.Is this version available now? I contacted my distributor and they total me it's not available till next year.
Mark - try what Electron suggested... copy the ElkRM folder under c:\program files and make a second copy - like ElkRMS2 or something... then open that folder and change the IP in ElkRM.xml or just open ElkRMS from that copy and set the different IP. You'd need to manually make a shortcut for this new copy - but in theory it should work. I just have no way or reason to really test it.I put in all my serial #'s for the different panels but It's a pain having to change the IP address's all the time to switch panels.
Is their a way to somehow have two conf's setup and switch between?
Mark
