T Travis4710 Member Oct 4, 2016 #1 Just installed ELK RP, version 2.0.34, and when I tried to import my account file it gives me the following error. Any suggestions? Attachments ELKRP.png 23.4 KB · Views: 11
D Del91574 Guru Oct 4, 2016 #2 What's the history of the panel install or RP install? Where and what is the existing account being exported from?
T Travis4710 Member Oct 4, 2016 #3 Panel was installed in 2014. The existing account was exported from the same panel. I updated computers, installed ELK RP on the new computer and when I tried to import the elk account I received the error.
D Del91574 Guru Oct 4, 2016 #4 Why not just drag the panel in by connecting to it? Could also have to do with DB security and setup of the old RP vs. new RP. Blow out the entire install including the hidden folders and try again?
D drvnbysound Senior Member Oct 5, 2016 #5 DELInstallations said: Why not just drag the panel in by connecting to it? Could also have to do with DB security and setup of the old RP vs. new RP. Blow out the entire install including the hidden folders and try again? Click to expand... The thing I dislike about having to do this, is that I lose all the comments I've entered into the rules. Having said that, I do agree that this would be an easy solution in this case.
