Elk used to have that capability, but it was removed from the M1.
Too many people turning things on like water sprinklers after a period of time without turning them off.
You can set up that operation with multiple rules.
Define the zone as a non alarm zone definition, else the alarm will activate when violated. This will not trigger the dialer to dial out.
Whenever Zone becomes not secure
And Area 1 is armed away
Then turn on output 100 for 10 minutes
Whenever output 100 turns off
Then turn on output 1 for 5 minutes
...more or less syntax.
If you want to trigger the dialer to dial out after 10 minutes, then define another zone and interface an output to trigger the zone input:
Then turn on output 3 for 5 seconds // Output 3's relay contacts connect to the new burglar zone.
