IVB
Anyone been able to successfully use an Elk temp sensor with a non-elk program (ie, MainLobby or CQC) to tell what the temp is in a given room?
I have 3 of them mounted, and I can't get CQC to display the temp. If I login via the Elk ethernet IE program, check the climate, then logout, it pushes the temp to CQC.
Before I go learn the Elk serial protocol to see if the problem is on the Elk pushing temp changes over serial side, or on the CQC side, i'd like to see if anyone has looked into this already.
