From reading this forum, it seems that after some wiring troubles, folks have gotten the RC1000/2000 thermostats from hai to work with elk m1 gold... Can anyone confirm if you can adjust the temperature and heat/cool modes, etc via telephone? You could probably trigger a rule, but wondering if you can actually set the temp via a touch-tone phone (omni supports this). Also, I thought I read something about the humidity function not working on the Rc2000 via elk but can't find it now... any comments (can you write a rule based on humidity and temp)? Thanks.
