I have cameras now under the eves of the house.  These eves are aluminum and the cameras are out of the weather, generally, but clearly outside.
The wiring is all inside -- it goes up inside the eve into the house, and is not run along the house outside at any point (I ended up getting lucky). I used regular cat5 unshielded interior wire, since I had none of it exposed.
I ran them directly into a POE switch. In retrospect I am wondering if I need some kind of lightning suppressor in front of the switch.
I've found a few, but frankly all cost more than the switch (and yes, I realize that it is possible it could go THROUGH the switch to other devices, but the switch is the most likely sacrificial device).
Are these needed? Are there any cheaper 8-port ones (I saw some in the $150 range)?
And do they do any good without a shield?
Would you bother for interior runs (at least in this sense interior)?
