I can't say I can completely agree Work.
In the case of the M1, when you consider multiple home runs for the data bus....remember, the M1 can only run 4K total length end to end, so when you look at that as far as home runs with multi-conductor cable, that is only 2K in a multiple homerun, which is very easy to hit on any install with any sort of distance or multiple bus devices.
It may not happen in a McMansion or tract home, but the larger installs, it's definitely something to keep in mind when planning cable runs out.
@ SDA, the older systems (assuming that's what you had) usually required a conductor for each key on the keypad in addition to whatever any LED or display needed. Bad back in the day for retrofit, but helps out now.
