apostolakisl
Just bought an Eye-Fi. Liking it a lot so far. It is an SD card that has wifi built into it. It is primarily meant for digital cameras but could be used for anything I suppose. It has a small USB device you plug into your computer and install the drivers. Then you pull the sd card out of the device, leaving the device plugged into your computer, and put the sd card into a camera or other sd device. Whenever a new file is loaded onto the sd card, it is transfered via your wifi to the device plugged into the usb on your computer which loads into a folder on your computer.
It would appear that the computer with the usb recevier plugged into it and the camera both need to be in range of the same wifi signal.
I have used it for my digital camera only so far. It takes about 10 seconds or so after you shoot a picture for it to show up on your computers hard drive.
The SD card is also a regular SD card. In otherwords, the images are still on the sd card just like normal and you can still pull it out of your camera and plug it into a normal sd reader and the files are there like normal.
They also have options for automatically loading the images to a webservice like facebook, costco, flickr, and a whole bunch of others. Also it can load to an ftp server.
For $40 on amazon, this is pretty awesome.
