felixrosbergen
Hi All,
I wanted to get confirmation on sme items before i have my meeting with the LV installer for my house and tell him exact what i want.
- For an indoor speaker or piezo screamer, can i run 22/4?
- For any ELK keypads all i need is cat5 right? Or if local code requires is 16/4 firewire (my installer should know). From what i understand the power for the keypads is coming through the cat5.
- For a outside siren ELK RT150 with SL1 Strobe where i want to be able to activate the siren and strobe separately (to not annoy the neighbors but still show that an event has happened when i come home) and monitor tamper can i run 22/4? I was thinking these are 3 circuits which could all use a common negative? Is the 22 gauge wire ok for the 1A draw of the RT150 at 12v?
- What is typical when sensing windows open for when your have 2 windows in the same opening (i.e. double wide window whith 2 sliding panels totalling 72" width) to run the wire over the sensors in series or to homerun each sensor?
- Should i ask for Normally Open or Normally Closed Door/Window sensors. I just want to know whats most common and allow monitoring of the circuit. I want the circuit to be intact when the window is closed and the circuit to be open when the window is open (or the wire is broken). I get confused with the read switches. Is the normally closed 'closed' when the magnet is there (thus window closed)?
Basically i am planning to instuct the LV to run the following from the alarm panel location:
- Run Cat5 to all 5 keypad location
- Run 22/4 to indoor speaker location (for initial announcement, later on announcements will go through whole house audio)
- Run 22/4 to outdoor siren (RT150 with SL1)
- Run 22/4 to several Motion sensor locations on ground floor (2nd floor i will do from attic later)
- Run 22/2 or 22/4 (whatever he wants) to windows and doors and install recessed window and door sensors. At least on ground floor and possibly on upper floor if the price is reasonable.
- 16/4 for whole house audio speaker from basement to each set of speakers with cat5 to keypad locations (16/4 runs through the keypad location as well to maintain flexibility). I'm most likely going with Nuvo (so wouldnt need 16/4 by keypad) but want to keep is flexible. I may change my mind to Logitech Duet with a multizone amp of some kind.
- Is cat5 to doorbell chime location enough? From what i understand the from and back doorbelt and transformer wiring all comes together in the chime box. I plan to either A) split the doorbells from the chime and make the doorbells inputs to ELK and the Chime an Output. OR disconnect the chime use the ELK indoor speaker as doorbell.
All LAN and CATV is taken care off already by running 3/4" conduits from basement/attic to LV mudrings in all rooms. For ALC lighting I have conduits from attic/basement to switch locations and have extra gang at switch location to allow for scene switches and cat5 wiring. This is all done bu the electrician, but the electrician wont do the alarm/speaker stuff. I already have extra cat5 to thermostats and doorbell.
