I have one smoke detector i'm trying to wire up. I have it so that it chirps when i test it (not sure if it's supposed to chirp or full sound) but then it does a loud 'beep' every 50 seconds which the manual says is ' other fault / trouble' or 'test switch -failed'. It does report an alarm to the elk according to the log.
only thing i can think of is that we're using an 880ohm resistor as EOL instead of the 820ohm that the elk calls for, but it's the closest i have.
If anyone is active and can help, i can be reached on AIM: ahreno msn: [email protected] yahoo: ahreno
