I have Elk M1 with Isy and Insteon Garage Kit and have found instructions showing how to get this done if you have an INSTEON KeyPadLinc, however in my case I just want to use F1 key from the Elk Navigator Keypad. I have searched around but not found much on this specific scenario.
So in my case neither of the below help much...
http://wiki.universal-devices.com/index.php?title=ISY-99i/ISY-26_INSTEON:Garage_Door_Kit
http://forum.universal-devices.com/viewtopic.php?t=4092
I've already done some preliminary testing/work on it, but I'm stuck now with problem that door just starts to open then stops. Maybe I have a timeout setting wrong...
Here is the rule from ISY (I do have Elk Module installed in ISY also)
If
Elk Keypad 'Keypad 01' 'F1' is Pressed
Then
Set 'Garage-Relay' On
ElkRP Keypad F1 Keys currently set as follows
Key: F1 Activates Event: 00 = Disabled Illumination Event: 1000 = No Event
Current Garage-Relay Insteon setting in ISY set as follows:
Checked: LED on TX
Checked: Trigger Reverse
Momentary A: Triggered by either On or Off
Momentary hold time (seconds): 0.5
If
Then
Checked: LED on TX
