I bought a HA7Net 1-wire unit from Embedded Data Systems. It is a web enabled - cat5 connected controller for a 1-wire network. I also bought all the weather devices from Hobby Boards and now i need to integrate them.
1. Is there any weather software out there that will work with this combination of hardware? Everything i have found is for a USB or/and Serial connection - not the cat5/web connection that the HA7Net controller utilizes.
2. Does the HB Wind Instrument include a temperature sensor? I see three addresses and one returns a temp - i guess obviously yes - but i didnt see it documented anywhere and want to confirm.
3. The Temp/Humidity/Solar only returns 2 temperature addresses - no Humidity or Solar in the HA7Net unit - could there be a compatibility issue with them and the HA7 unit? I assumed (ha) by definition all 1-wire components were compatible.
4. Same question w/the Barometer, does it include a tempeature sensor? Again, i see it so i guess so - but I dont see the Barometer address - unfortunately the HA7 only puts out 5volts and the Barometer board needs at least 14 volts so i guess I can get a transformer and wire it up directly to the board - and that might be why i dont see it?
Anyway, lots more questions along this line but my main point is i dont even know what i dont know - if i get some basic direction maybe some of these "integration" quesitons will sort themselves out.
thanks all - pete
thanks all - pete
