pete_c Guru Nov 24, 2025 #16 Try a hardware reset, re configure the IP, then ping the Ethernet interface. Press on the Ethernet interface when pinging. If no pings then... Sounds like your Ethernet port / chip is bad.
J jpmargis Active Member Nov 25, 2025 #17 I haven't read the whole thread, but I wonder if you can ping anything with the laptop? Your OPII might be just fine.
