Got all the new z-wave equipment installed and running. LOVE :wub: the Z-wave lock integration. But....I can't seem to get the OPII to correctly address Z-wave scenes.
For instance, I have two scenes for the entry lights. The "normal" night scene has only the lights on the front of the garage illuminated at 25%. When someone opens a door, or motion is detected in the driveway, all the lights (front garage lights, garage side door light, house side door light, and main entry light), all come on at 100%. Using the Vizia RF + Installer tool, I can setup the two scenes and assign them to the 4-button controllers. What I can't do is find out how to map the scene setup by the installer tool into the OPII.
The OPII has a specific setup for scenes, i.e. 4 scenes for every 8 units. Inside PCAccess where I define the names for scenes, there are associated numbers. In the example above the two entry scenes are #61 and #62. When I created the scenes inside the installer tool, I assigned them those two numbers. When activated from the 4-button controller the scenes work fine. However, if I call the scenes from inside the OPII, ALL the lights in the bank of eight go on at 100#, no matter which of the four scenes are acitvated.
I believe that the scene information is stored on the switch, and not the controller. If that's correct, it would seem that scene #61 on the OPII is not the same as scene #61 in the installer tool.
Suggestions?
Suggestions?
