HAI RC-80B only works with backlight?
theedudenator
I just installed a HAI RC-80B.
Everything seems to work ok, heat kicks on, cool kicks on, fan only kicks on.
I woke up this morning to a cold house.
It seems that it work ONLY if the back light is ON!
So I can override the temp and the furnace will kick on.
But I have to keep pressing the overide button (or any other button) to keep the furnace running.
As soon as I let the backlight time out and shut off, it turns the furnace off.
From what I have read this is normally the opposite problem.
When I get home I am going to try to jumper the backlight to always be off, but figure I would post here first.
That is strange. Does your system have a common wire? If so, maybe it's become disconnected. If not, then perhaps your fan relay is going bad. I'm grasping at straws here.
I am not sure if I have a common
Red
White
Yellow
Green
I also have a blue wire that was connected to my old thermostat, I did not connect it to the new one.
My furnace worked fine with the old thermostat...
I wonder if my furnace is sensing a change in the load when the backlight kicks off, thus starting the shut down sequence?
[/quote]
I have heard before that the backlight can cause issues on these thermostats. Usually a separate power supply is recommended, or turning it off might fix it as well. Keep us posted!
It sounds like it doesn't have a common if the unit only works with the backlight on. You'll have to check the heater to see which is the common on your unit.
I changed the jumper on the unit to have the backlight on all the time.
Now it works fine.
I looked at my furnace and the manual. I am not seeing a "common"
W1 W2 Y G RH
W1 and W2 are jumpered together at the furnace.
So I don't have a common on my furnace then?
Looking at the wiring for my furnace I do not have a common connection.
So now I need to run a separate power source?
Now it works fine.
W1 W2 Y G RH
[/quote]
Initially the same thermostat would cause problems with HVAC motherboard and the thermostat itself would act up.
I had to add an additional power source for mine. Its been a couple of years now and all is well.
