Thought I would post some newbie lessons as I got my UPB working with my new HAI system this weekend. I was pulling my hair out thinking my house's old wiring was keeping my controller from communicating with any of my switches using the serial PIM. I have a 2000 square foot house built in the early 60's. A majority of my circuits are not grounded and the circuit breaker panel is definitely original. I thought had gotten lucky in that each switch location I had chosen to start with had both a hot (black) and neutral (white) wire. Important to note, since most of my searching could not find an answer: a ground wire is not needed for UPB. I am not an electrician, but i am pretty sure grounding is good wiring practice, but clearly wasn't needed per code when my house was built. Maybe that is obvious to everyone else, and probably should have been to me since the PIM does not have the grounding prong on the plug. I had myself mostly convinced that was my problem though...
I had gotten out an extension cord to literally plug the PIM into the same circuit as each of the switches I had installed. And I had gotten absolutely nothing. No communication and nothing being setup. I had gone through each of the troubleshooting items from the HAI knowledge base. I was about to track down an old serial header card for my computer, as it is new enough to not have a serial port, so I could try to find them using UPstart and my PC. As I brought the PIM and cable over to my work area and unplugged the phone/serial cable I noticed that the jack fit just a slight bit oddly (I don't often use anything with a phone cord these days...
). I had plugged and unplugged all the connections twice already, but upon further inspection of the jack I noticed that two of the sprung wire/pins in the jack were grossly misaligned. Some tweezers, an exacto knife, and some very careful bending and I reconnected everything. SUCCESS!!!! I can not tell you how good it feels the first time you tell a light to go on from the computer or by some lines of programming and it just happens.
Problems like these are always the last place you look... right?
Ok venting/story over. I was proud of myself for finally getting it to work. Fiance, was much less so... :unsure:
