Looking to put one in each bathroom to trigger lighting when stumbling into the bathroom at night. I haven't been able to find a clean way to install these without using a battery and without using the wallwart 'Battery Eliminator.' I have the walls open and am running lines for security and data, so I have the opportunity to keep to wire these motions.
http://www.smarthome...-ADAPTER/p.aspx
Not sure why Insteon doesn't make a toggle/dimmer switch with an occupancy sensor built in. Using stand alone motions to trigger a bathroom lighting scheme seems like a bit of a hack.
I should mention that I'm also using an ELK M1 to handle security. It's my understanding that some of the PIRs for the common areas could be used to trigger Insteon lighting scenes with the ISY. Maybe I should get some super small PIRs for the bathrooms since I'm not concerned with accuracy or false alarms (haven't seen any though)?
