apostolakisl
Seeing your situation, I would recommend surface mounting a center channel speaker under the TV. Then mounting your L/R speakers to the outside of the windows. You'll also want surround speakers in the ceiling behind your seating area. Surface mount center speakers are readily available and look good, and you already are surface mounting the TV, so it won't look cluttered at all.
I would also recommend centering the windows and TV on that wall. I know you will say it doesn't look as right from the outside, but I bet you can shift things around a little to make it work.
