Hello Fellow Cocooners...
ebalders
Hi guys, figured I'd put the first of many posts here. I'm just starting the installation of a OmniPro II system in the office of the company I work for.
Right now I have everything on a table while I test and figure things out....
I am using the OPII with a 83A00-1 12V Power Hub. I have two HAI 75A00-2 Card Readers wired up, with two users(Codes) set up in PC Access. I have assigned each reader to an area. I want to control access to different parts of the office by adding or removing areas to the users(Codes).... Right now the only way it works is to add or remove readers form the list of valid readers for each Code. Is it possible to use Areas in the way I have described?
Appreciate any help I can get.
