I am able to connect to the M1XEP with a router or hub, but was trying to connect using a crossover cable I made base on these instructions:
http://www.littlewhitedog.com/content-8.html
I tested continuity and it is good. I was told that you need to use static IP to connect, but I am a little rusty on networking.
The manual talks of jumpering the static IP jumper. Is it just a matter of going into the M1XEP setup and changing to Static IP and putting a random IP in, or using default?
Thanks in advance.
Thanks in advance.
