I have decided on UPB over Z wave and would like to get started installing them soon. I only want to get a few to start so I can learn about them before I buy more.
My goals are the same as everyone else but my big goal is to improve the WAF. Currently there is no WAF...she could care less about HA. So, I want to wow her so she can see the benefits...I will never get her to see the 'cool' factor so I am not looking for that.
I would like to mix and match Gen I and II for cost savings. There are some areas where I don't think I need the Gen II benefits so I figured put in Gen I to save some money. So, with that, this is what I think I need.
Gen I Switches only: 9 switches
Gen I Dimmer only: 3
Gen II Switches only: 7
Gen II Dimmer only: 9
Gen II 3-way Dimmer: 3 (All with 3 total switches)
Gen II 3-way switch: 1 (3 total switches)
I split them this way because I am still not clear if you can get a switch only without dimming capabilities.
I plan on integrating them with Elk and CQC.
So, with this info ( I'll give more if needed) where should I start? What manufacturers should I go with for Gen I (SA) and II (PCS, HAI) ? Since I am mixing, what UPB PIM should I go with? I know each has a different feel and I won't know which I like until I play with them but just looking for a starting point...what ones play well together.
Eric
Eric
