Ok, since this is a test run, can I use z-wave sensors in combination with say CQC or Homeseer to run a "pretend" alarm system.
So from her perspective, she will get the touchscreen which shows when a window / Door is open. But from the backend side, I can skip the cost of the control board initially as well as use a 30 day trial of one of the above software packages. That delays my expenditures until after I get the a-ok. All I would need are sensors and software. And of course a couple UPB switched/modules.
(And I understand this is NOT an alarm system per say, if at all, but from her user point of view it achieves the desired effect).
Then I can use the same sensors with an Elk or HAI after she decides she likes it.
Will the software programs deal with IP cameras and UPB directly? i.e. without a security panel?
