Hi,
I will soon be moving into new construction and would very much appreciate a sanity check on my proposed automation setup before I pull the trigger and dive into this time-consuming and not inexpensive hobby (I pre-wired as much as possible (so I guess I'm already committed to some extent!
), so everything will be hard-wired except for the Z-wave components; there are no Wi-Fi controlled items, as the home network is all CAT6.
Hometroller S6
- is it worth it to upgrade to PRO for more RAM based on the following automation?
Control panels
- Android POE wall-mounted tablets (I can't post links based on me being a new member, but it's the geekland POE ones) running HSTouch as a regular app. Anyone have experience with Android POE tablets or can suggest other POE tablets that are wall-mountable?
Lighting
- UPB; also with dry contacts or step-down LV stuff to control garage doors
Alarm
- DSC 1864 PowerSeries using EnvisaLink 3 IP interface
Audio
- I already have a Russound MCA-C3 whole house controller (4 zones) with DSM media server, but may change to multiple Sonos Connect:Amps
Cameras
- Hikvision POE outdoor/indoor bullets and domes
Roller Shades
- Somfy motors powered via low-voltage wiring; I pre-wired for 16/4, so I guess I can go RS485 or use Somfy RTS with the Z-Wave to RTS interface
Locks
-Z-wave
Thermostat
-Z-wave, but have CAT6 wired to thermostat locations in case I come across any ethernet-based thermostats (any recommendations?)
Basically, I just need reassurance that this setup would work under Homeseer either natively or with their plug-ins. Is there anything that I'm doing that's out of the ordinary or that the seasoned automation folk on here would discourage or recommend that it be done a different way? I'll also post on the Homeseer boards.
Thanks!
