Hi all! This is only my third post here, but all of the responses from my previous threads two have been a great help to me and I can see that there is a lot of knowledge at this forum. We are nearing the trim-out phase of a new house and I'm going to have to order dimmers and keypads soon. In our previous home I had retro-fitted all of the switches with UPB dimmers and had only marginal success with them. For this house I want something that is reliable, functional and high quality so I am thinking RadioRa2 is probably the ticket. I don't think my electrician is completely up to speed on RadioRA2, but he is happy to install whatever switches I want and is fine with me procuring them. However, I just muddled through the RadioRa2 training and I am still a bit out to lunch in terms of what exactly I need.
Almost all of our lights are going to be LED with most of them being Halo incandescent cans that are going to be fitted with an LED module. I also have some LED fixtures from companies like Modern Forms, Progress Lighting, and Cerno. I will eventually have some LED rope and strip lighting that will need to be controlled as well. I think the only non-LED lights I will have are going to be some LV cable lights and possibly some LV landscape lights. I have several questions relating to the system, but I'll just start with a few of the most relevant questions and see what kind of can of worms it opens up.
First, aside from cost is there any reason to look at anything besides RadioRa2? Reliability, durability and longevity are the top qualifiers, so whatever I go with should get high marks in those areas.
Second, assuming I go with RadioRA2, I'm super confused in terms of trying to determine what dimmers I will need. I figured I'd just default to RRD6ND for all of the LED loads - or RRD10NA if necessary. Is it possible I will have some loads that will be an issue even with those dimmers? Initially I believed that as long as I have a neutral dimmer I should be fine with virtually any fixture, but it sounds like even then, if the bulb isn't compatible I might still have trouble.
On the flip side, Lutron bills the RRD6CL as a CFL/LED friendly dimmer, but it doesn't have a neutral. Pretty much everything I've read recommends that a neutral always be used, but that creates a bit of a disconnect between what Lutron is showing versus best practice. Confusing the matter even further, I also recall part of the Lurton training recommending a neutral be used whenever possible. Is the RRD6CL only recommended for LED loads when you don't have a neutral available, but otherwise you should use one of their dimmers with a neutral?
For my LV loads I guess I would want to use the RRD6NA so that I can use either electronic or low voltage transformers? And probably the same dimmer for the LED and rope and strip lighting which will require a transformer/power supply?
I think what I really need is a dumbed down primer on modern lighting technologies. In any case, once I get the appropriate dimmers I should be good to go as the system programming seems pretty straight forward. It's just a matter of getting the correct units for the fixtures I have.
I would greatly appreciate anyone who can shed some light on the above. Also feel free to add any additional words of wisdom or recommendations. Just keep in mind that beyond rewiring a switch and extending a circuit, my electrical knowledge is pretty basic.
Thanks!
Matt
EDIT: I have been looking at the LED fixtures I am buying and all of them seem to say dimmable with ELV dimmer. Does that imply that I should be looking at RRD6NA for those? If so I am then thinking that the HALO cans with LED adapters will utilize the same dimmer and maybe that is the only dimmer model I will need to purchase. This is all very confusing...
Thanks!
Matt
