I'm looking for something that is able to determine if an electrical single is present or not through Linux perferrably.
The senerio I'm trying to figure out... I have a hydronic heating system and I want to be able to do some kind of reporting to which zones are requesting heat (I have 3 zones) and at which time of day, also comparitive to the temperature outside.
So, in the simplest broken down form, I just need a way to determine if the zone sensor is on, or if a signal has been sent to it. I know the voltage (24v) of the circuit and I have the temperature thing already solved.
Most of this is done in perl, I just don't have a way to get the information to the system that the zone has been tripped by the thermostat.
So does anyone know of a way to determine or watch a eletrical circuit or query if the circuit is powered in Linux?
