Homeseer home troller
JoshFarr
I am doing a lot of reading online about home automation and wiring. I am really leaning towards a HomeSeer system to automate everything. So some of the questions I have are
1. Is the home troller better than a computer?
2. Do I have to have a security system to monitor surveillance cameras or can I just use homeseer? I'm just not sure why I would need all the inputs.
3. I am new to this and have looked at control4 but I want to be in charge if I want to change something that is why I am considering homeseer. Is there another alternative that I should explore?
4. Does anybody have a pic of a home troller all hooked up? I want to see how I need to configure my wiring closet.
5. Is there a site or topic that would help me understand how to better grasp all of what homeseer can do and how I can make it work for me?
Thanks for any help
People that have the home troller seem to be happy with it from what I have read here and on the HomeSeer Forums. It's more reliable than a plain PC with HomeSeer installed and offers restore features as well.
As far as alternatives HERE is a listing of all home automation software in a searchable index. :)
I would stay away from Control4 if you are a DIY type as you mentioned above.
I have a friend (end consumer) whom liked my home automation and decided to go with the contractor recommended Control4 system for her home (1.5 million? total?).
3 years later she wants nothing to do with Home automation and wants the Control4 system out of her home. She is computer literate but not a DIY person.
Once you move on there is no going back Nick. Home automation is very addicting.
The Hometroller is a small footprint PC with multiple serial and USB cable connections on the back of it.
I have two PC's running Homeseer today. Both are using mITX low power boards. Both of them are configured in the same manner utilizing one USB port.
I am using one Digi USB hub to two Digi Edgeports such that I have configured 16 serial devices and 5 USB devices all via one USB cable.
This allows for a smaller fooprint. To reduce wiring "clutter" I also went to using RJ-45 to 9-Pin serial connectors for all of my serial connections.
To further reduce the cabling you can take the USB to the network in a similiar fashion using a Digi USB Anywhere. That said though I used a Lantronics USB to network device for the USB to sound card and the Way to Call device.
You can also build yourself a pico PC and run Homeseer software on it if you want to micro footprint.
I also have a MiCaseVerde unit that I purchased to "play" with. Maybe because I was used to Homeseer and biased a bit; I shut it off after a bit and went back to using Homeseer.
Here though I have X10, Insteon, Z-Wave and UPB. PIMs are connected to Homeseer and my HAI panel (except for Insteon).
Thanks Pete. I had been all ready to go MiCasaVerde and discovered the Homeseer unit.
I really just wanted to control 2 or 3 lights in my living room. But it is really starting to snowball! :nutz:
Pete,
Do you still have the MiCaseVerde? I have a friend who wanted to Z-Wave monitor a lock and control a few lights. I tried to ensure that was ALL the scope, so he might be interested in buying that from you.
--Dan
