I think I accidently posted this in the incorrect topic before. The details below describe how to get Premise loaded on Vista, yes it is possible! I've pasted two methods that should work. Remember to add a restore point in Vista BEFORE trying these though, just in case. FYI: if you follow the etc6849 method below and are running an updated 32 bit Vista SP1 install (or even a fresh SP1 install, I've personally tried this method on both), Premise should work for you. It took more than just relocating the Premise install directory for me, but one person got that too work also.
I have been running Premise for 3 weeks now and the more I use it, the more I like it. I highly recommend Premise. Similar software (if there is softare that does everything Premise does) would cost a person $500+. In fact, I believe Premise used to be $800 for the dealer addition.
etc6849's method:
"Thanks for the tip. I guess I was being impatient when I said it wouldn't work. Here are the steps I did to get it running:
1. End the install application under the application tab in task manager.
2. Next, I manually ensure the premise services under the services tab in task manager is stopped. Don't stop the individual installer processes (under the task manager process tab) as this will uninstall premise and remove it.
3. Reboot. Makes sure the Premise services are stopped. Click on the setup.exe again, but this time select "repair."
4. Reboot again and ensure the premise services are started (they should be).
Permise is working pretty well for me under vista. So far I am controlling my receiver via rs232 and I'm able to select media to play."
samgreco's method:
Advanced Cocooner
" I recently reinstalled and I seem to have solved it by installing Premise to a directory off of the root. So it's C:\Premise not Program Files. Install fine and works great.
Interesting as well, the browser seems to perform WAY better if I use localhost in the url on the server, and use the IP address on any client PC. Hmm..
This is on Vista 64 BTW."
etc6849's method:
samgreco's method:
Advanced Cocooner
