I am in the process of putting together a security and basic home automation system. My first priority is security, but once I saw that most security controllers could also do automation and HVAC control, then I wanted to take advantage of these features.
I am currently looking at the HAI Omnipro II and Elk M1 Gold. Not too sure which one to get because I haven’t quite figured out the full integration. On the security side, both setups offer what I need which is about 8 security zones and 3 or 4 fire zones. I want to integrate 2 or 3 keypads for control of the security system. This part seems easy.
The real questions come on home automation and HVAC. On the automation my main goal is to setup my HVAC into 7 control zones. The Omnipro II is capable of up to 64 thermostats and I believe I could use the Omnistat2 or other thermostats that are Zwave or UPB compatible. From what I understand, the advantage to connecting the thermostat to the HA controller is the ability to have all the thermostats be controlled by the controller for various modes and possibly, but I don’t really think this is possible, control one thermostat from another. The part I am not very clear on with the zone control is how the thermostats actually integrate into my current HVAC. Currently I have a single stage HVAC system using a gas furnace that supplies my first and second floor. I would like to break this up into 7 zones and realize this requires modifying duct work and adding motorized dampers for each vent so that it can be independently controlled. What I can’t determine is how the HA controller works with the thermostats and dampers. Do I need to purchase a separate zone controller or is the HA controller all that I need? I really hope that I can install my 7 thermostats in my 7 different zones and connect all my motorized dampers to a relay board in the HA controller. When zone 3 calls for air conditioning, the HA controller would close all the other zones and open zone 3 and switch on the air conditioning. Is this how things would integrate? Is extra hardware needed other than additional relay boards and thermostats? What thermostats could be used to accomplish this for each system?
I also have a Pronto 9600 I would like to integrate into the system and I know the Omnipro II can easily integrate with the Pronto for theater control. Is there a cost to do this for the plugin? Can Elk work with the Pronto?
Also, what is needed to do the system programming for each system? I obviously will have to do some basic coding especially if the zone control scenario I described above is how things will really work. Do I need to purchase extra interface devices or software to program the Omni or Elk controllers? If so, what would I need?
With all this being said, is there any input on which controller would better fit my needs? I have the ability to get an Omnipro II for the same price as the Elk M1 Gold, but am concerned that since I am a DIY’er that I may not be able to get the support I need from HAI.
I am leaning to the Omnipro right now because of the Pronto integration and the pricing deal I can get with it. I can get the security I need with either system, but I really need help figuring out how to integrate HVAC zone control and if one system is easier to do this with than the other. Since I need so many thermostats, one system may have a great advantage if I can integrate less expensive thermostats with it.
