How wire output from NVR to Omnipro II
pac1234
How wire output from NVR into the Omnipro II ?
(attached drawing of correct wiring?)
NVR Hikvision DS-7716NI-SP/16  (NVR)
Program setup
- Default status: Low Level (Greyed out and don't think I option to change this)
- Triggering Status: Pulse (Greyed out and don't think I option to change this)
- Delay: I have options of 5sec, 10sec, 30sec, 1min, 2min, 5min, 10min - (Is this dwell time - time period the system is in a given state?) (The lights that will be triggered by the NVR, I was planning on using OmniPro programing to determine length of time they will be on)
Output on back of NVR: 1, 1G, 2, 2G, 3, 3G, 4, 4G
Omnipro II
- Take the "1" lead to a open zone "Z+"  ?
- Take the "1G" to the Auxiliary 12 VDC add connect to its "GND"  ?
- Set Zone Type as "Auxiliary" ?
- In Setup item for zone resistors is set to "Yes"  (1000-ohm zone resistors are used on all the zones). So I assume I need to use a zone resistor ?
Thanks!
