gcimmino said:Would something like this work?
It's $33 at Digikey and has a voltage output that varies with humidity from about 1.3v to 3.5v.
You'd set the Elk Zone to Analog (Type = 34). From what I've read elsewhere here, there's an 8 bit DAC over a 14v range. This should give you about 40 unique values over the 1.3v to 3.5v range of the sensor, good for at least 5% RH differences.
Just a SWAG, but might help.
Squeak that wheel!upstatemike said:Maybe the M1 Platinum will have dip switches to disable the resistors.
