I know this is slightly off-topic, but looking for ideas...
Switched over to cooling mode yesterday, and I'm noticing very little air is getting to the upstairs bedrooms.
Background: I have 3 zones (one for each floor), each with an automated damper that opens/closes to allow air to the appropriate zone.
I made sure the two bottom zones were off (set thermostat temp higher than room temp) and I could verify both dampers closed (I watched them close). The 3rd zone damper opened - so I would expect air to be blowing upstairs and not the downstairs 2 zones.
However, both of the downstairs zones are "bleeding" air - more than the upstairs zone is! (If I set the thermostat so that the zones are supposed to blow air - a lot comes through, therefore I'm calling this "bleeding air" or "leaking air")
Therefore, I assume I have something wrong...
Questions:
- is it normal for a damper valve to not close all the way? Could this be normal?
- The system has a mechanical damper (I assume to keep pressure from an overflow situation). I've manually moved it - no change.
- Could it be that the upstairs is too far away for the air to get to? (I moved in the house in August so we really didn't use the AC much before)
- If this is the case, recommendations? hire a pro? add a fan blower in the ducts?
Sorry - I know this isn't a normal thread... but everyone here seems pretty handy, thought maybe someone would have some ideas for me. Thanks!
Questions:
