I have been using HS for around 6 years, and that can actually be a bad thing. Let me explain, I did not know a single thing about VB script, until I needed it to do some things I wanted in HS. Now, 6 years later, I can write just about anything in VB.... well HS VB that is! There are subtle diferences in true VB and commands that HS can use. I found this to be true when I would write ASP pages that worked fine in HS, but would not work on a server.
So.... here is my problem, I wrote a script to grab weather images, and save them locally. It works fine in HS, but I can not get it to run outside HS. I have looked the code over, and just do not see what is causing this. If someone could take a look, and let me know, I would greatly appreceiate it.
This is actually for my CarPC. I have Wi-Fi Hopper installed, It will auto detect my home network when I start the car and grab the images when I leave the house. I could also connect with my cellphone as a blue tooth modem, and it would also be detected and grab the images automatically. Also whenever an unsecured Wi-Fi signal is detected while driving around, Wi-Fi Hopper will automatically connect to it, and can trigger this script to update the imagesimages. Next are images from local area traffic cams.
Note: Right now, as it stands, this script will work perfectly with HS as it is to grab just about any image and save it locally at whatever interval you tell HS to run the script. This can make loading local weather pages much faster with the images cached to your hard drive in advance.....
Here is the code, you know it's not much when it's only a 2k zip file!! The "weather.txt" file is basically an INI with the list of Images names & URL's to get them from. The RoadRunnerWeather.vbs is the script.
