upstatemike said:
Main thing for me is how fast a thermostat reports changes to Homeseer. With my Nest thermostats even though they are monitored over the Internet a manual change is detected instantly and the voice announcement of the new setting happens before you even take your hand off of the thermostat. Is Ecobee that quick? If not I might need to move to a serial thermostat or s super fast reporting Z-Wave model.
Ecobee demands no faster than 3 minutes between polls or they threaten to cut you off.
That seems excessive between polls, but I fail to see any reason why I would need any faster updates. The ecobee is the closest to home automation and needs very little remote control. I only turn my heat nd A/C back and forth, when needed. That happens sometimes twice per day in my climate. Other than that I have never touch it as it flips between two climate styles with heat and A/C with many user definable climate styles and remote room sensing to match your location in the house.
My HA does Automatic Intelligent Setback on it as well as Automatic Intelligent Recovery. Having owned many different brands of stats, none ever had Intelligent setback, despite knowing all the needed parameters to make an educated guess. I don't play with temperature or fan cycling Ecobee does all that very well. I do play with climate settings though to cause intelligent premature setbacks in the evenings of warm weather. I don't like going to bed in a warm house. It also controls my HRV and humidifier.
The sensors do not wander as badly as all the other stat brands I tried, measured against 8 other sensor averaging and is not affected by internal heat or room draughts like most are. One brand varied the displayed temperature by 4 degrees F with heat being called for vs heat not called for. All designed by software nerds and not by HVAC people.
