subpoenaman
I currently have a Gadspot 4ch dvr (gs2001) works great on my home network. I have cable (rr) with a linksys wireless router (wrt 300n) with 3 wireless laptops and two desktops plugged into the router (cat-5).in the router I’ve set the port forwarding to the following : app Name =gadspod: port range forwarding start 2002: end port 2002 protocol tcp/udp (both) ip address = 192.168.1.118. joined dyndns and setup my account as : found.dontexist.com . I then setup the dvr as follows. Ip mode; static: video port 9000: web port 2002: ip 192.168.1.118: net mask 255.255.255.0: gateway 192.168.1.1 :No passwords at this time. This dvd came with a program called NetViewer D8 and from the laptops and desktops you can view the cam. When I goto a neighbors home and using Iexplorer and type the address : http :// found.dontexist.com:2002 It will load the same netviews d8 on that machine which makes me think I’ve connected. But when I setup the netviewer I enter the following (same as my home machine) Host name http://found.dontexist.com:2002 : Ip address : 192.168.1.118 and video port 9000. try and log on (no password set) and it comes back connection failed. Is there something I’m missing . the gadspot people give me different answers with each phone call. thanks for any help
